  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah dont see Troy on often .... im getting a bit "over it" myself .... be focusing more n my career and less on whoring these coming weeks need to get priorities straight me thinks
has it been auctioned yet Liz?
Originally posted by Kyles
Oh well maby we can pop over and see you preform!!
hehe tomato dress :D
hey liz went to look at a house in St Andrews today .... had all Irish dancing trophies in it!!
It sucks how antything to do with the law takes soooooooo long!
Yeah i dont get much time either these days.
I had uni today and my lecturer was going through the assignment.. The others who have already done the assignemnt in previous classes said it was too hard and poorly explained. So for us as a trial shes made it easier.. when she was going through it she was going "ahh we dont need to do that bit.. take that part out, and um.. i just want u to do this instead of this..
I was like YES!! ... Easy assignment now. Will take all of 2 weekends to do no doubt!
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
    • Finally back on the ground and once around the block for the first time in 2+ years
    • Ok a solution was found. I had left the factory oil temp sensor in and it was hooked up. My car never had the triple gauges.  Apparently when you delete the factory pressure and leave the temp sensor connected it triggers the oil light on the dashboard. Disconnected the temp sender, no more light.  I still haven't gotten around to look at the diagrams to figure out how/why they are tied together.
