  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
tired ...... :zzz:
went to bed after i came home from gym last night but i had to get up again for a glass of water and my legs we so much like jelly that when i stood on them they just collapsed from under me and i fell to the floor .... haha funny feeling not being able to walk temporily!
