  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Why I Fired My Secretary. . .
Two weeks ago was my 45th birthday and I wasn't feeling too good that morning. I went to breakfast knowing my wife would be pleasant and say, "Happy Birthday!", and probably have a present for me.
As it turned out, she didn't even say good morning, let alone any
happy birthday. I thought, well, that's wives for you, the children
will remember.. The children came in to breakfast and didn't say a word.
So when I left for the office, I was feeling pretty low and despondent.. As I walked into my office, my secretary Janet said, "Good morning, Boss. Happy Birthday". And I felt a little better that someone had remembered.
I worked until noon, then Janet knocked on my door and
said, "You know, it's such a beautiful day outside, and it's your
birthday, let's go to lunch, just you and
me." I said, "By George, that's the greatest thing I've heard all day. "Let's go!" We went to lunch.
We didn't go where we normally go; instead we went out to a private little place. We had two martinis and enjoyed lunch tremendously.
On the way back to the office, she said, "You know, it's such a
beautiful day. We don't need to go back to the office, do we?"
I said, "No, I guess not."
She said, "Let's go to my apartment."
After arriving at her apartment she said, "Boss, if you don't mind, I think I'll go into the bedroom and slip into something more comfortable" "Sure!" I excitedly replied.
She went into the bedroom and, in about six minutes, she came out carrying a huge birthday cake ----- followed by my wife, children, and dozens of our friends, all singing Happy Birthday.
And I just sat there ----
on the couch ----
Naked.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
