  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Dan: yay for rice :)
Sub: Yeah i take my car to work everyday and Auto is far better for those purposes :D ..... i thought today there was going to be huge traffic jams with trains might be on strike ..... but i actually got to work in 20 mins cos there was no traffic .... usually takes me 45!!
