  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha shaft feels dumb now, i was serching for quick reply then remember it ain't on at the moment :D lol wat a dick :D
sooooooooooooooooooooooooooooooooooo my engines makin a really really really really faint knocking noise i dont like it :( hopefully rebuild time ain't on the cards for me :(
adrian :)
oooo doesnt sound good :D shouldnt need rebuilding ..... look how much paul had to thrash the guts outta his and it still is holding together ..... just. Besides its not like Autos get that much of a thrashing - cant get into the higher rev range for it :D
Have your belts been changed?
hahha yeah you can still get autos in the higher rev range but trust me i dont think youur engine about to die!
change belts see how that goes :D
On that piece of wisdom im off to bed - whore everyone tommorrow
outta here!
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
