  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Niz, Thinking of a car like this? http://www.antilag.com/events/finalbattle/...es/DSC02447.jpg
Im in love :love: oh well even if i put R33 up for sale i couldnt aford one!
