  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hey all :D
rather eventful day this morning, rocked up to work and the place was locked nobody had prep'd anyhting up and even more noone was there
guess who was that lucky bastard who had to get the shop up and running in ten mins?(impossible)
adrian :cool:
dan, a mate of mine has the s15 veilside kit in that electric blue colour
and you think it looks good in picture, in the flesh it looks absolutely mint
but i'm with paulie, jash's border kit on his s15 is ultimate :cool:
:uh-huh:
adrian :D
anyone up for bubble tea tonight?
angry adrian on :(
yeah, i was pissed this morning, opening the whole shop takes about 2 hours, i had ten mins lol ontop of that calling the staff who were suppose to be in there at 9am to ask where the phuck are ya :cool:
angry adrian off :)
adrian :D
