  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah i probably wont actually get the SAFC II installed and tuned til the FMIC goes in ;) Do it all at once!! :)
Looks like all my friends are getting "tightarse Xmas" this year ......*better start swiping some stationary before i leave today* Mum ..... here have a pair of scissors for Xmas .... and Dad heres a stapler ..... Mel you can have a highlighter :)
mexr .... you religous ... tell me to mind my own business if you like ... its just most of my family of JW's and dont celebrate it either ... so really i only have to buy for mum n dad. :)
Fane .... sounds serious :) ... you going to use it for track work?
you can still tune your engine much better with an safc mex.... :)
i can see it helping heaps because the NA relies on good tuning so much.... all your Air/Fuel mixtures can be perfect...tuned for all your mods like exhaust and pod and shit.... as you get more you can forward the timing etc etc.... :) i can see it helping...
haha going to buy a big arse turbo Fane? Nah well mines auto so i cant have over 300rwhp anyway without going and replacing transmission with a hoity toity jap one .... which really aint worth it .... i just want a reasonably quick fun car .... but i just couldnt spend a huge amount of money on it - it would seriously make me cry the day you go to sell it and you've spent $10K in mods and only get $9k for the car haha :)
nah i wanna buy a play toy and make my GTST daily driver .... i so want an ferrari red R32 GTR .... oh yeaaaah!
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
