:ghost: theres a message that comes up to say that my message has to be at least 10 characters long ..... so here is the 10+ characters :D
back to my box now
So when are you moving into whore central??
Or won't Telstra allow any more lines into the house for fear of blowing the exchange up?? :wassup:
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
be a bit of a tax deduction or rebate from it though yes?
Yea , you get the 10% GST back and can claim the interest paid on the loan.
Still have to have some serious backing to find the $172K in the first place though :D
Cheers
Ken
Ken .... nah twos company .... threes a crowd :) Paul and Aidwin can hav ehteir little love nest :D
Sil80 .... nothin would surprise me there!
Chaos .... found one that i would liek to apply for - will do that tommorrow morning :)
i dont really go clubbing as much as i used to now ..... these days i more for the BBQ pissup. Not as much ciggerette smoke and sleezy guys.
* Ken thinks what he was doing at the SAU BBQ *
Hmmmm , oops
Cheers
Ken
But you posted that was one of secret fetishes :flamed: :inlove:
Cheers
Ken
haha Paul no longer has my pile of clothes for a keyboard desk .... that was funny and pathetic at the same time :)
:D yeah SAU BBQ's are pretty sleezy ....we need more of them ..... but unfortunately Macka seems to be more interested in the feathered kinda birds these days :)
Ken, secret fetish? Paul + Aidwin? ... how about we throw you in as well ;)
mmmm go that leopard G-String :aroused: ..... handcuffs and whip should be buried in there somewhere as well (pauls room is like an archelogical dig everytime you need to find something)
Are we grossing everybody out yet :D
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
