  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Ken .... never know your camera might come back with some xtra speshal footage on it ..... its our xmas pressie to you :D
yeah there wasnt paul .... oh well
I only do those vids as the personal camera assistant..
Will have to be quick cos Al ( Sexzilla ) is bringing it up tomorrow arvo to Hyperdrive at 4pm.
Cheers
Ken
Ken, You having a meeting with Al then? I hope you can finalise some stuff:D
Yea so do I .
Am interested re. his costings for a website but hopefully we can get something happening quickly.
You can cruise over if it is your want :D
Cheers
Ken
more importantly .... whats happening with runt?
atm , nothing cos I haven't been pushing to sell it lately ( too busy ) but will have to get serious about it's fate shortly. :headspin:
Cheers
Ken
awwww poor runt ..... spray paint her red put a CF bonnet on her an dit can be my xmas present ...... in my dreams :D
The carbon bonnet I can do but the colour change is a bit harder.
Will a 1/24 scale model suffice and how grateful will you be . Hehehehe
Cheers
Ken( evil lurker )
Ken, BTW, not sure if you read my congrats for the ENYOP Speed series win, So congrats again:D
tep , read it a few days ago but will take any admiration from anybody.
Thanks
Cheers
Ken
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
