  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Adrian .... please take the drift stuff off ya sig its annoying as Autos cant drift :D known fact
Wll got my covering letter done .... sugar coating plus .... all i gotta do after lunch is bring my resume up to date then its sent off :)
haha yeah good old monday ..... depression on the start of another working week.
wonder if theres any more Jenny Craig Chocolate Mousse left .... does Superman Pose "To the fridge"
burnt roof of mouth ..... again ....
See i look at it like this:
Auto box is good for 300rwhp .... now even a lot of the manuals in the club arent doing over that unless they've had a big arse turbo put in them..... which the average joe blow cant afford anyway.
So really ..... i can get my auto making the same amount of horsepower as a lot of the manuals in the club (high 200's) and really yor just as quick and its better for dragging ..... whales cant drift anyway so its not like you need a clutch for that ..... so i'll just save the $5000 needed to make it a manual (for no powergain or real purpose whatsoever) and go on a holiday :D
My 2c
Bad about the wisdom teeth - wanted to take mine out too but they are still in there.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
