  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hobby at the moment is finishing the unpacking and to clean up. Going to do some gardening soon... well troy will do all the hard work of course pulling out all the dead or tacky trees/plants that i want gone, while i sit back and encrouage him hahahaha ill do the fun stuff.. like the planting. I think its fun.. no idear.. never done it before.. Its just going to be hard keeting it alive. I bought some flowers for the frount garden a few weeks ago.. killed them in 2 days. Aparently it was the hot weather that did it.. thats what ill keep telling myself anyways.. IM NOT A PLANT KILLER!! :D
Yeah still working as a kindy teacher. The kids are being wonderful at the moment.. its just the staff are being petty idiots. Both my center boss and my state boss are on my side thats what counts. Work has offered me to work casual hours next year. Basicaly with the money i will get with centerlink, i can only earn a cetain amount before they cut payments. Work said they will employ some one that works around me. Say if i can only do say 3 to 6pm, the other person covers the rest of my normal 8.5 hour day. So i just work as many hours as i can untill my centerlink payments are cut down.. and then i stop because its not worth it if they cut my centerlink payments down. Im lucky they are doing this for me. Troys moving in also before i start uni (hopefully) so ill be fine for money. Its not like im used to having lots anyways.. all of my money at the moment goes on bills.. i should actually have some money to play with when troy moves in and im at uni.
moving is deffently not cheap. Bond, rent, etc etc.. you need at least a grand for a normal priced place.. then if its not a furnished place.. thats more money.
I have a washing machine for sale though ben, if you need one when you move :D cheap only $50! Twin tub... really easy for a bloke to use.
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
