  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
guys can be just as bad if not worse .... yeah i was scared my ex was going to do something too .... cos he would go on drug binges and then call me up to go rescue him so i thought that one of these days it was just going to kill him and i dont want to know about it when it happens .... thats why im glad he's over the side of the world ... best thing ever .... now i dont have him contacting me .... i dont have his friends going "andy and i were just talking about u the other day" .... its been good cos ive been now able to get on with my life without him still trying to laden all his problems onto me.
i must admit im really content with my life the way it is right now ..... apart from the job situation that needs sorting out drastically. Ive let go of all the bullshit that happened in the past and i dont think about it anymore ... the best thing i ever did was getting out of that situation.
oh well he'll do it when he's ready .... you cant force people to make changes ... although my friends gave it a good shot.
unfortunately people get into the pattern of thinking that maybe it doesnt get much better so they accept the situation.
    • I see what you mean on that last paragraph and makes sense. I am leaning towards because I made the repair/filler area large that I didn't use a long enough block. Will minimise the area and let you's know how I go. This is random but I noticed when I put epoxy primer it felt flat but that's just temporary.
    • Tried to repair with filler only. The block is a foam block but quite hard and I put a velcro on it for sandpaper, the hook and loop system. It's not one of those super soft ones that just follow the panel. Similar to a dura block.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
