  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
guys can be just as bad if not worse .... yeah i was scared my ex was going to do something too .... cos he would go on drug binges and then call me up to go rescue him so i thought that one of these days it was just going to kill him and i dont want to know about it when it happens .... thats why im glad he's over the side of the world ... best thing ever .... now i dont have him contacting me .... i dont have his friends going "andy and i were just talking about u the other day" .... its been good cos ive been now able to get on with my life without him still trying to laden all his problems onto me.
i must admit im really content with my life the way it is right now ..... apart from the job situation that needs sorting out drastically. Ive let go of all the bullshit that happened in the past and i dont think about it anymore ... the best thing i ever did was getting out of that situation.
oh well he'll do it when he's ready .... you cant force people to make changes ... although my friends gave it a good shot.
unfortunately people get into the pattern of thinking that maybe it doesnt get much better so they accept the situation.
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
