  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
if so can your workshop install stock spring on a r33 skyline (93 model)
if yes just pm me cuz im off now later
*Sigh *
Right you lot.
pwptpf is dead cos I am gonna kill him.
Mike , your noob posts and phone calls are no different to everyone else who rings so don't feel bad.
All exhaust pipes are black since they removed the lead content in fuel and the smell is probably a bad seal at the filler neck.
yes we have spring compressors and can install stock springs. we even have a set in stock if you don't.
The dyno will be running by the end of the week and we can check your a/f's then or we have a mobile a/f and can take it for a blastif you want to bring it around.
Nothing we do is for free but we try to look after SAU members the same as SST.
Right , any more ****ing questions ?????hehehe
Cheers
Ken
I have a question, but I don't know if its really relevant here.
Why does it hurt when I urinate?
(Ignore me).
YOu could have a Urinary Tract Infection (bladder infection). You should see a doctor as they will prescribe anti-biotics. It is diagnosed with a urine test.
Drinking lots of water can help flush out the infection as well. But in men - because the urethra is longer than a females - there is more chance of the infection becoming more severe. So if drinking lots of water doesnt help - see a doctor - because the pain will become unbearable.
Or you could have an STD...... such as Gonorrhea - which has similar symptoms to a Urinary Tract Infection (frequent and painful urination - is one symptom)
from nursey liz
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
