Ok so i got a highmount TD-06 set up on my R32 and was jsut wondering if anyone else had the same turbo, what mods do they have and what is the turbo good for at the end of the day.
With the right mods to the Rb20 what do you recon the over all figure i could get out of it without spending thousands on a complete rebuild and what rpm are you making boost???
Cheers B
https://www.sau.com.au/forums/topic/88536-td-06/
i have one, but ive got a blown motor, so havent dynoed it, best person to talk to is ROY, they are a great turbo for the rb20 and can make aroung 250rwkw with supporting mods. im hoping to get as close to 300rwkw with mine, but i have a worked engine. I may end up geting T67 to replace my TD06.
https://www.sau.com.au/forums/topic/88536-td-06/#findComment-1598545
have currently bolted one to a rb20 with an 8cm rear housing....in terms of mods, nothing major just front mount pod exhaust made 230rwkw and actually ran 12.2 last night at WSID (congrats tim)..... my old setup was rb25 with cams etc etc made 265rwkw with a 12cm rear housing......in all truth to see a 20g reach 300rwkw is a big task....however the 25g/t67 will see you well over 300rwkw, however on a rb20 you'll lose alot down low.
What really freaked me out was when we put a 700hp garrett gt turbo on a rb20 with a stock motor with frount mount and exhaust and boost, it made 266rwkw!!
https://www.sau.com.au/forums/topic/88536-td-06/#findComment-1598721
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
