im just posting this topic to know where everyone meet up and hang out, cause usually it was saturday nite at livo but now they block off most of the parking spot hardly see anyone there where have u guyz moved too PM me and let me know cheers!
https://www.sau.com.au/forums/topic/88761-hang-outs-and-meeting-spots/
have they closed the KK carpark at Livo????
yeah they did is there any othere place where we can meet up i reckon villawood maccas that car park is huge u can fit so much cars there and also its near maccas :P and also there is serval way in and out
since they closed down the parking on weekends, now theres just bogans from campbelltown crowding whats left of the place. f**k that we need a new chillout spot. villawood maccas hmmmm
Edited by DarKZer0
haha, I agree with that mate :O We are pretty much regulars on a Saturday night Chill at high st maccas and wait for a commodore cruise to go past, and go crash there party :) It's awesome fun and a great road for it.
haha, I agree with that mate :cheers:  We are pretty much regulars on a Saturday night  Chill at high st maccas and wait for a commodore cruise to go past, and go crash there party :)  It's awesome fun and a great road for it.
hahaha when will you be there next???
Villawood Maccas + Bunnings car park is huge. However, there are only two entries/exits not very far apart on the same side street.
yeah i guess but its a nice car park pretty big and i dnt think they can close it hahahhaha and also maccas is near by,
so the great western highway u guyz meet there every saturday or what?
Haha funny avatar.
anything happening tonight out penrith way?
didnt hear anything can someone pm me where u guyz meet or if there is any other place like livo maccas that place was awsome !
Is their anything happening out penrith on any day/night of the week now? Since Panthers closed down the Evans club the town has been extremely quiet everywhere. So quiet that I can actually lineup inside Krispy Kreme at 2am rather than 400m down the carpark :D
the police and the government is f**king us around, closing down all the meeting place, i reckon modifiying ur call should be legal and that u can drive them around without getting defected. but if kunts who drive stupidly then it alrite to defect their car since they are driving recklessly and that they will indanger others. cause its unfair to those who just like to modified their cars so it looks better and its like a hobby.
we gotta fine other meeting places around sydney................ anyone have any ideas plz post it up we are up for suggestions
unfortunately its the miniority that ruin it for the majority.
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
