Hey all just got a black r34gtt 38000kms, complied last month :cheers:
ill post some pics sometime soon :)
I live in syd and am looking for a good place to do a custom 3 inch full exhaust maybe.
also it came with a non standard BOV, just wondering where i can get a factory BOV as i dont want a defection :S
tnx for any help
Edited by Shado34
https://www.sau.com.au/forums/topic/89447-new-car/
tnx all for the help, ye its a HKS SSQV Blowoff Valve Kit i think.
Trying to geta digital cam, will try poat some pics soon :)
Welcome to another 34GTT owner :)  Damn our private community is growing larger and larger everyday - saw three 34s in the city last night not including mine :(  Was it you?
no wasnt me i havnt done a city run yet :)
Edited by Shado34
https://www.sau.com.au/forums/topic/89447-new-car/#findComment-1615126
yep thats pretty much defectable.. as many car mods are..
If u let it off whist police are close, and the police know what it is. (though they usually call hwy cars to come and look at the car).
Get a stock one quick! :)
Have you tried HiTech Mufllers? I think they are good. Though dont know and never been there.
https://www.sau.com.au/forums/topic/89447-new-car/#findComment-1615131
hey all, i was wondering if its normal for the boost guage to be at -0.5 to -0.6 when idle (i know it should be a negative figure at idle but this low?), it goes up to the lo boost and hi boost fine when im driving but this just worries me abit ;)
Edited by Shado34
https://www.sau.com.au/forums/topic/89447-new-car/#findComment-1616124
yea dont worry about it.. The stock gauge is always usulaly very wrong.. bet a aftermarket one its better.. and it has zing factor :D
i havent seen one thats wrong, have you?
the only thing i notice is that they are slow to react (electric) and the markings dont give enough detail.
https://www.sau.com.au/forums/topic/89447-new-car/#findComment-1630712
Man, you've got a sunroof....
couldn't find one with a sunroof, unless it was auto...
btw nice car, have you got any plans for it?
nah mine dosnt have a sun roof, i had a look at one with a sunroof but it effects head room...
I plan on getting power fc first and soon turbo back exhaust; then i might work on a sound quality audio system :)
https://www.sau.com.au/forums/topic/89447-new-car/#findComment-1661249
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
