  • Replies 58
Posted Images
as topic says, im after some pics of the 260rs sideskirts, the dayz ones, and some other brands and i dont want nuthin too bulky and over the top :D
cheers
Brad
Updating my gallery at the moment, so there will be a heap of Stagea pics with the Dayz bodykit in there.
Check these out tho:
https://www.sau.com.au/forums/topic/89592-side-skirts/#findComment-1617641
cheers
Brad
Here is something a bit different. These skirts were on my Series 2 when I bought it. Do not aske me what or whose they are. Sorry about front spoiler - being repaired.
Marc2
ps Will try and have better photos of my car and another Series 2 with a DAYZ kit tomorrow.
https://www.sau.com.au/forums/topic/89592-side-skirts/#findComment-1623081
Marc2
Your kit is in the hyper rev mag. It says" M's FACTORY" whoever they are.
https://www.sau.com.au/forums/topic/89592-side-skirts/#findComment-1623843
Long as less no shifty looking boat crew member took that as well, (dont' think ernie has mentioned it yet ... l'll find out), l'm more than happy to let u use it.
long as less l a wing gets made with this kit!! :P
Edited by NRGIZD
https://www.sau.com.au/forums/topic/89592-side-skirts/#findComment-1625605
I cant make moulds as such, and I'll have to take a look at how it goes on, etc. Dont want to f* up my dayz bodykit!
But if the sideskirt set needs to be borrowed as such so moulds can be made, and orders placed to that mould maker, then we can give it a go.
Im in Adelaide, who has mould-making contacts?
https://www.sau.com.au/forums/topic/89592-side-skirts/#findComment-1625615
Going to check out a couple of fibregalss mould shops here in Adelaide this Saturday (hopefully places are open on Saturday). Im full time Mon-Fri so Sat is the only day I can look-see. Can get an indication if copies can be made (without screwing up my skirts), how long it'd take, quality, price, etc.
Hands up for numbers? Who wants Dayz REPLICA skirts? If I can go to some shops and say "take my skirts, make a mould up & do Xamount of copies while you are there, and make 'em good, damn good", might be able to sort some pricing out.
Postage.... need to source the right size boxes, and I can have TNT deliver them. But we'll get to that later. Let me know about the intrest, and I'll see if I can get a quote.
https://www.sau.com.au/forums/topic/89592-side-skirts/#findComment-1625746
I have the contact who does moulding, i know i am in Melbourne, but thats not an issues.
Moulding doesnt damage in any way what is being moulded. Ive seen moulds been taken before from a bonnet/gaurd and the original was not damaged at all
I would be interested in a replica kit, full kit. But i wouldnt want to pay more then 1000 in total, specially coz ill have to freight it, paint it etc etc as well... and looks aint my priority ATM.
https://www.sau.com.au/forums/topic/89592-side-skirts/#findComment-1625822
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
