welcome to the country. what area in aus u in, if you wanna meet some people have a look in the states section and get to know a more local crowd
Am down in Perth, flip lovely down here. Do have one question for you guys, how on earth do you cope with the 60km/h speed limit, is driving me absolutely nuts.
Soon guys, soon. Well am new to Aus and the whole V8 thing is cool, new to me as back home the "in cars" are astras, golfs etc.... (Sad i know)
But have always wanted a Skyline, ever since i saw the one tested on Top Gear, would love an R33 GTR, would LOVE the R34 but im guessing thats a bit out of my price range. What sort of power/speed/price does the R33 go for? You will prob laugh if you knew what car i drove.
My accent is alright, originally from the UK so its not the most South African you can get, get some real bad ones.
so what did you used to drive?
kia , echo, barina, VW bug? haha :lol:
and you dont want a R33, they are whales.. you want the R32 :)
(waits for flames from the R33 owners)
LOL well i had an awesome little car. Was an Opel Corsa, sortof like your Holden Barina but was the sport model, branches, freeflow etc.... Even dragged a Subaru Forester 2.5 which i know is prob not a big deal but for a 1.6 i was impressed :)
R32, u say they the one to go for? What sort of price can you pick one up for?
Thanks guys. Slim that is an awesome looking car mate. Is there anywhere around where you actually get to give it some stick!!!!!!!!!!!
cheers :)
.. and there are a few tracks to go to..
But it never gets hammered on the public streets..cos.. thats.. illegal.. so.. I ..never..do that.. heh..heh..heh..
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
