yeah, then you will need a balancer puller to get it off.
There are three 6mm holes in the front of the balancer that can have long bolts screwed into for the puller (some pullers don't come with the 6mm bolts though so you may need to go to a bolt shop)
Have you got the crank bolt out yet?
https://www.sau.com.au/forums/topic/89976-rb26/#findComment-1622384
does anyone know how to remove the harmonic balancer from an rb26? is it just a matter of removing the nut that in the middle of it?
Undo the big bolt in the centre ( 32 mm head ) several turns but dont take out .
Then use you puller on the 2x6mm threaded holes , you will need 2x6mm treaded bolts, once the pulley comes loose remove the big bolt and the pulley will come off .
If you dont have a puller buy one from supercheap or any auto parts shop , there are cheap Chinese ones ( about $20 ) .
Edited by wrxhoon
https://www.sau.com.au/forums/topic/89976-rb26/#findComment-1625336
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
    • I definitely know the first rule here, look first, ask second. I've seen many people get roasted 😂 I found a few diagrams for the RB, but I'm yet to come across one for the VQ. From what I have read, the pump gets the +12v along with the FPCM, and it's the negative wire that gets passed through the resistor to regulate the voltage. So I assume I can just ground the negative wire at the pump to eliminate the FPCM control. But I really wanted to see the VQ circuit diagram first to make sure I understood it correctly. Once the new pump is in I'll do some testing to see how it behaves, and in the meantime, I'll keep looking for a wiring diagram. Thanks for your help mate, your time is greatly appreciated.
    • Maybe? I have the Supercheap ToolPro low thingo. It has a somewhat smaller diameter lifting "bowl" than you would expect on a workshop grade trolley jack, and a split rubber pad to suit that diameter. It clears the "N1" style skirts I have. Probably wouldn't if the jack's bowl and a suitably larger rubber block were in use. Having said that though.....you only need the rubber block to exist on the inner side of the pinchweld, so could carve away any rubber that fouled the skirt, leaving some there for "insurance" </simples>
    • I used to do that (sills with rubber jack block).. ... then I got side skirts, and there's no way for the jack to actually work there, the jack pad itself on the jack is too big. Is the answer to use a... smaller (?) jack? Hmmm.
    • I have too much trauma from every skyline I've ever seen having crushed jack points/pinch welds lol.    Yep, works 100%, it's what I use when I'm using the quick jack. Don't know why I can't also bring myself to do the same thing when I'm using a jack. I blame the skyline PTSD.
