I decided to buy this model, Legalis R because its soo quite...
So i hoped!!....AND IT IS!! Its like, driving a std car with a little tiny tiny burble!! Infact, often engine/road noise out does the exhaust.
I cant feel much of a difference, thats probably coz i havnt installed the cat just yet, but mmm so happy
Link to Fuji website about my exhaust... http://translate.google.com/translate?u=ht...Flanguage_tools
Cant wait to put the cat and split dump in, will be fun :P
BTW, anyone wondering, i got it for 1100 airmail deliverd...
Edited by AlexCim
https://www.sau.com.au/forums/topic/90146-got-my-new-fujitsubo-exhaust/
  • Replies 58
NOOO should have got the power getter so i could see some pics installed.. damm u.. ahhaahh..
So you cant even hear the exhaust at all?? not even a tiny bit??
Is that the way you always wanted??
Edited by siddr20
Written at the bottom, 1100 air mail
I couldnt get the power getter for E-WGNC34, only this or the regaris. I didnt want the regaris as it was 94dB at 4800, this is 84dB
(to me, that is crazy low)
Plus, i am trying to keep the sleeper look/feel about the car, so this suits me perfect :P
Previous to this, i had a custom made catback with xforce muffler. For me(quite lover) it was quite loud, and the single cabin doesnt help when it comes to cruising at 2,000 at 80 for several KM's so yeh, quite is what i wanted.
Anyone that wants a cheap catback for a Stag, i want to sell this one
It cost me 590 to make, so make me an offer for it..
Edited by AlexCim
Wow, that exhaust looks almost identical to my one, but mine isn't as shiny anymore. maybe i've got one of those too. i can't hear the exhaust at all really unless i'm behind the car loading the boot.
looks really good though, congrats
Have a look under your muffler and see if it says FGK, if so, chances are you have the same exhaust
When i said i cant really hear it at all, i am not just trying about idle, i am talking about the whole rev range. At ~2000 you can hear a tiny tiny rumble, i think thats where it resonates most... apart from that, engine/road noise is the go with loudness
Cat goes in today! Ill post photos when im done
And here is the cat!
its a BOS importing stainless steel inside cat
The power difference for this exhaust over standard isnt HUGE, but its noticable. Its because i chose quite over powerful...
The boost is much stronger now, so is induction noise and also its spools really hard during hard gear changes. Power is a lot smoother too
Cant wait for the PFC and turbo upgrade... oh and the manual conversion :)
Oh, and to anyone wondering, the car sits 12cm off the ground at the lowest point, this is the bit just under the rear sway bar.
My car also sits at 405mm and 380mm F/R centre wheel to gaurd... soo i wont lower it much because then ill be illegal, so drop it only another ... 1.6cm (0.8cm adjustments when i get the shocks)
Yep
When i met up with Burns and he was complaining about the car being too low and hitting things, i thought, how could that be because the car looked PERFECT at the height it sits
What getting this aftermarket exhaust as taught me is that no one that will get a aftermarket exhaust can expect to sit too high off the ground. I wanted to drop the car to about 350-360mm, but now, i wont take it below ~370 because otherwise it will be
a) illegal
B) impractical (i still carry heaps of stuff too)
But still, i just the height of 370. Ill just fill it with some GTR wheels when i get around to it and it will be all sweet. I think PranK has std suspension and his GTR rims fill the gaurds perfectly.
On the Fuji website, it says that the exhaust causes the std car to drop to 13cm off the ground. Given sag/age, i think 12cm sounds about right
I know this is an exhaust thread, but ground clearance and ride height are important considerations when choosing an exhaust. So there is a mixture of exhaust and ride height dimensions that might come in handy following.
Before we get into it I should mention that I have raised mine 8mm (using the next up circlip groove) since the pictures where taken. It now sits at 345 mm centre of wheel to guard at the rear (350 mm at the front) and at that height the STANDARD exhaust is exactly 100 mm from the ground. That's measured under the rear stabiliser bar same as Alex's. At that height it just clears the local speed bumps that I usually use to check clearances.
Note that the front 350 mm and rear 345 mm gives a 10 mm rake (nose down) when measured at the sills. At 405/380 Alex's is sitting around 10 mm nose up, which is what mine was like when I got it. The 10 mm nose down makes a big difference to how it looks, much more agressive stance, so to speak. For the guys getting the Whiteline/Bilstein Group Buy kit that is 1 circlip groove up from standard, both front and rear.
The standard exhaust is ~2.5" (62 mm) OD, so a 3.25" (83 mm OD) exhaust is going to be 20 m closer to the ground. Even a 3" (75mm) exhaust is going to be 13 mm lower. I can't raise the exhaust up any higher than standard because it will hit the stabiliser bar. So I might have to go up another 8 mm in the spring height to give similar ground clearance to what I have now.
That will leave the front at 358 mm and rear at 353 mm (still with a 10 mm rake, nose down) which is 47/27 lower than where Alex's is at the moment.
:D Cheers :)
Edited by Sydneykid
Ill keep this thread updated when its my time to buy the suspension package too, my goal is to keep it perfectly legal...
Ill also update when i install the split dump/front in one, but i doubt that will sit any lower really..
Edited by AlexCim
Turns out i do have the same exhaust as you, but only form Cat back. i'll have to get the autosol onto it to get it looking like yours though, mine has been on there at least 2 years
I was the original stagea trialer for the SS split dump/front pipe
There was some problems with the angles of the pipe which are getting sorted now. Also, the o2 hit the exhaust manifold
I am just waiting on my revised pipe to arrive and then ill give it a go installing it again (was a bitch of a job the first time around .. but now i know what to do/how)
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
