All measurements in millimeters
HKS GT3240 - 580 PS Output
Manufacturer: HKS (garret)
COMPRESSOR:
-Wheel- 54 Trim - 60.3 Inducer / 82.0 Major
-Housing- 100 Inlet / 60 Outlet - 0.60 A/R
TURBINE:
-Wheel- 84 Trim - 54.0 Major / 58.7 Exducer
-Housing- GT25 inlet / External GT30 outlet - 0.87 A/R
TRUST T78 - 700 PS Output
Manufacturer: GReddy (Mitsubishi)
COMPRESSOR:
-Wheel- 33D
-Inducer- 66.0
-Exducer- 90.0
TURBINE:
-Wheel- T78
-Exducer- 65.0
-Major- 74.0
Conversion from HP to PS
horsepower (HP) 1 = horsepower (PS) 1.014
MEGA
https://www.sau.com.au/forums/topic/9026-hks-3240-or-t78/#findComment-134483
driftr33,
If you are actually thinking about putting these on your car then go the 3240, the T78 will be way too laggy. We have put the T78 onto a 4litre V8, but due to the extra capcaity the turbo isn't as laggy. And remember, the only way to utilise all of the power available from these trubo's is through the use of cams.
See'ya:burnout:
https://www.sau.com.au/forums/topic/9026-hks-3240-or-t78/#findComment-134498
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
