I will be there for sure, not quite sure if I will be racing though. Sounds like it will be another fun track day :P
The form says the car must not exceed the road legal noise volume, I am pretty sure my car does. Roy has an externally vented gate as I recall and he was at the last Maserati track day at Sandown. So will they let it slide?
Edited by MSPEC
$175 paid by today, $200 paid after today.
OUCH ... sure make the wrx club sprints looks cheap ...
Yeah Maserati Club is for over-paid poofs that wear womens panties on their heads.
:P
(Thank god my car doesn't need any work on it for a little while!)
:P
hey until you can carry Rb26's on your shoulder you can't talk!!!
(yep my car does need work)
HAHA who is going from SAU.
I will make you a deal, I will stop being soft if you pay the $200 entry fee :P
Just think of it as if you dont run at sandown those nice new semi comps will be wasted until feb next year, which is the next event of the callender
But by that time next year I will still have lots or rubber on them if I dont go and an extra $200 in my pocket. Might give it a miss, few other events coming up that I will need some spare cash for.
Be careful how and where you store them. I may be over reacting but they do harden and go off if not being used. So try and make sure they are in a cool dark place.
Hate to see you rock up to a track day in 5 months time with what looks to be healthy rubbe ronly to find they have as much grip as tonka tyres.
Has anyone got any facts when it comes to storing these types fo tyres?
Thanks mate, I probably wont go for more than 2 months without using them for at least a weekend. They are still on the car now anyway and will be until I can get another set of rims for the wet weather tires :)
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
