It looks like the 31st is the winner from our poll.
When - Friday 31st Jan 9.00pm leaving 9.30ish (usually that'll mean 10pm :P)
Where - Bunnings car park Mile End, on the city side of the car park, ie come into the cp from under the overpass if heading south (where we started on the joint LS1/Skyline cruise that rained).
Route - Something for everyone hopefully! Open to suggestions.
For those that wanted the 24th - go for it! But I can't make it.
CYA on the 31st ;)
https://www.sau.com.au/forums/topic/9067-cruise-friday-31st-jan/
  • Replies 56
Cool.Round taillights are the go.
S'posed to be a SMASA cruise sat night(25th) starting at
Bunnings Windsor Gdns at 7.00pm.These cruises are huge.
Be good to see some Jap content there as is mainly local
street machines.
Bit tired tonight, might postpone my R34 cruise till tomorrow night.
See if I can scare some 'old school' street machines!
Sometimes guys bring out some real tough cars to these cruises
so will be interesting.
I went to rego dept today & reserved some number plates ;
EVO 007. Watch this space!!!!!
31st cruise looks good, will be good to meet some new Skyline
owners,hopefully some of you will also come out to the drags the following Sat night for some burnout action.
See ya.
Originally posted by Pawley
...i guess im a virgin to all this, but looking forward to a cruise with  all them round taillights.
You and me both Pawley.
I hope to make it, just might have a bit of trouble keeping up! Spose you need to leave someone behind to wear all the heat from the local boys in blue... So is it likely any other low powered vehicle owners coming along?
Steve
Henry,
Yeah mate you guys are welcome to come along.
I don't think anyone would have a problem with a few LS1 Commodore guys attending (all good blokes & nice cars).
Hey Henry maybe Martin might bring the Ute along for a bit of an arse whippin' ?:) More like he'll bring the Snorer to whip arse himself!
John,
Bye bye S2000 hello EVO7. Nice choice mate!
ALL - You guys/girls do realise this cruise is proportional to the likelihood of RAIN! The bigger the cruise the greater the chance of it raining :):P
Thanks for your number Matt, Ill give you a buzz at ten when I finish work. Hope your not too far down south by then as I work at in the northern burbs. Ill try to catch up with everone as soon as I can. Does Anyone know the best people to install my Apexi Rev Speed Meter. Cheers Matt
See you all there its been awhile:D
Steve,
If I haven't already said it, "welcome to these parts" :P
Bunnings Hardware (& car park) is located @ 108 Railway Tce Mile End (actually closer to the suburb of Mild End South).
The car park can be entered from Sir Donald Bradman drive (formally known as Burbridge Rd) when heading west towards the Adelaide airport. You can also enter the CP from Railway Tce itself by going under Sir Donald Bradman Drv (Burbridge Rd).
UBD ADELAIDE Street Directory Map 117 grid reference M-13, well that's what my '00 edition UBD has.
If you look on map 117 of the UBD the suburb of MILD END SOUTH is marked in bold black type, directly to the right of this is Railway Tce.
That should get you there mate.
Matt
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
