  • Replies 56
It was the most popular of the 3 choices. Sorry dude :)
I'm guessing not everyone thinks the BDO is as important as you?
Less people on the road cause they'll be @ the BDO or too stuffed to be driving?
It's not gunna' be hot & so far doesn't look like rain, can't complain about that!
Hippy, all you need to do is fit a big f@ck off dragons head to your car, and we can cut a lap of the city, that way you wont miss out...lol
A skyline dragon (with others for good measure)
EDIT: you can even huck a few fire crackers out the window as you go past china town. Definately a good way to get on the news!
doglet,
I'm keeping my fingers crossed that the BOM have got the report right!?
ADELAIDE METROPOLITAN AREA
Thursday : Cloudy with a shower or two clearing during the afternoon. Mild
with fresh and gusty southwest winds.
Headline : A shower or two.
*Friday* : A fine, mild and partly cloudy day. Moderate to fresh southwest
to southerly winds.
Adelaide City Min 15 Max 23
Headline : Fine. Partly cloudy.
Next two days for Adelaide City :
Saturday : Min 15 Max 27 Fine. Sunny afternoon.
Sunday : Min 17 Max 31 Fine. Sunny.
hi there, I'm interested in going but like hippy, i'll be stuck with the chinese New Year celebrations till later. Is there a map for this Friday's cruise? Or can I contact someone after I've stuffed myself with food?? (about 10pm).
Slowest skyline? Oh, thought you were talking bout me... :)
Thanks.
adrian
Adrian,
Maps.... Hmmm... well I'm working on a route that has a bit of everything (hills/f'way/'burbs etc...) but I'm still learning the good roads myself (18mths in state).
I'll PM you my # It'll be easier that way.
Matt
Looks like a bit of a mixed bag really. Old Skylines?..... Yeah why not!
VX/VU SS LS1's X 3-4+ (a few quick ones too!)
R34
R33's
R32's
Old school Skylines
S15
Evo4?
Dodge Vipers X 2
911 GT2
Niki 650 X 4
+ 7 postie bikes (2 with 100hp Nitrous kits)
Ok so the last few I made up :)
Hi Guys,
I’m new to this forum, but ill try to make it as well. If I find some replacement rotors for the GTR. I have a fault line appearing that threatens to swallow a rim. If I make it ill have in tow a couple of GTiR's and a DR30 (gas-turbo).
ADM
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
