  • Replies 56
Originally posted by cowboyb
Matt,
What does your skyline look like...hope I can recognise it when I'm there!
Dotcom, where's this temple with exotic dancers?! I'll give up the cruise for thaT!! I'm only human...
weather's perfect, should be a good nite!
adrian
Adrian,
Just remember the word TRUST & you'll find my car mate :D (it's burgundy too)
Exotic dancers - Traditional dancers..... could be interesting if the traditions included nudity :lol:
Fingers crossed the weather plays the game tonight too!
Guest GTRdotcom
umm look for the ricey front GTR badge of a maroon car, thats Whatisname's machine :shake:
Matt, nearly fooled me, got me excited about dragging some GT1/vipers off the lights... :eek:
Ok about the 'exotic' dancers...umm u wish :bahaha: they're more traditional ie. show no flesh... unlike the gals u guys used to @ the crazy horse
Hippy, if you come from Hanson rd end of Grandjunction, turn right onto Eastern Parade (ABS centre) and the temple is like 2nd or 3rd road on the right, just follow the traffic i guess, they'll have fireworks at midnight.
The Vietnamese temple is off addison rd, Butler ave or Pennington primary (my old school), look for the big Vietnam restaurant or Caltex service station
The weather is perfect, looking forward to catch up with you guys 2nite,
Cheers,
Dotcom :rolleyes:
Guest Cacophony
Hey guys
I was hoping to be catching up with you guys on this cruise, as I just bought my skyline this week. However, as Murphy's Law commands, my clutch is screwed.
Would like to catch up with you guys on the next one though! Looks like its going to be a nice cool night... should be a good one.
Cheers
:) Yeah like Dotcom said my car is a ricey R33. :lol: Sorry to get ya' hopes up Andy, a bit of Viper/GT2 action would be cool though!
Hippy sorry I didn't PM you my # :P I didn't check the forum until just now, after the cruise!
ALL,
Thanks for comin' along! Hope you all had fun?
A big SORRY for arriving late & my lack of organisation (had a few minor dramas b4 hand).
I'm sure we lost plenty of you along the way :P Hopefully those who lost us had fun anyway :)
To be honest I didn't quite expect to have that many starters :eek: Good effort guys/girls!
Lots of very nice & bloody quick cars on the cruise too!
For anyone who might of been wondering? whatsisname = TRUST 6
Till next time......
:D
Matt
