It looks like a uni report (possibly a thesis) so I would take everything in it with a grain of salt. Ultimatly the guy or girl was just trying to get a report together that gets a good mark. I'm not saying it did happen but a bit of number manipulation could have happened. BTW there is a fair bit of usless unrelated info in that report, I hope the supervisor suggests they cut it down.
Besides, I don't think dyno run testing of fuel is a very good way to compare fuels.
Edited by JCMarshall_Law
  • Replies 62
Posted Images
MRT's comments:
UPDATE as at 7th October
Re Illegal use and distribution of incomplete document
(if you have seen or read a fuel test document on the web.....)
To say we are surprised to see this document on the net is an understatement!
The document is wrong and incomplete!
We wish to publicly state that we accept no responsibility for the accuracy of this document.
The disappointing fact is that it was our aim to show the best fuel solution and not crucify the worst.
As this document has been illegally obtained, it now compromises our position to finish the full and final release of the complete (and accurate) document.
I cant go into details of how the copy was obtained, but I can say it was distributed illegally and we have had legal advice on what do do for several reasons.
its not accurate
it portrays MRT as approving the data (which is wrong)
and it compromises several other companies.
it puts us in an awkward position
We ask everyone who has this document to destroy it as it is copyright to MRT Performance and this is in breach (it clearly states this in every page) and it significantly compromises us.
We hope to come up with a solution shortly that meets everyone's needs and will allow us to list the full and very detailed complete report!
I am sure you will understand our difficulty in this situation
Sincerely
Brett Middleton
MRT Performance
http://www.mrtrally.com.au/forums/topic.as...511&whichpage=1
    • Kittens in first to claim dominance of the residence, then puppies later From past experience, the other way around can be problematic to say the least  Those weird "Dobby looking"  little kittens are not cheap....LOL
    • At least yours have parkour down pat. One of mine will still trip over his own shadow and fall over... He's a special type of cat... Ha ha ha
    • The question then becomes - was there any fluid coming from that hole before you did the rebuild ?    You may not have noticed, of course.   Depending on how you did the rebuild, the possibility has to be considered that somehow (cleaning ?)  fluid entered that hole and is now being 'forced'  out by small movements of the proportioning valve.   From the factory, there's actually a small rubber plug in that hole but with age and under-bonnet heat it's quite common for it to 'go missing'.  That rubber plug is designed to allow the venting process but also to prevent 'stuff' getting to the area (prevent corrosion, etc).   The plug is also not available as a spare part AFAIA. Personally I wouldn't race and buy a new master just yet but keep an eye on the area to see if the 'leak' continues.   If you're concerned about brake fluid damaging nearby paintwork, cable tie a piece of suitable absorbant material over the hole and remove/monitor occasionally.    Operation of the proportioning valve and the brake master itself won't be affected, but also keep an eye on brake fluid level, of course. In terms of a new master, the genuine part is getting expensive, unfortunately.  Amayama is showing AUD900+.   I was searching recently and there's an aftermarket part available from Japan made by 'Parts Assist': https://zenmarket.jp/en/yahoo.aspx?q=BNR32%2bBM50&p=1 Whether it's any good I have no idea, although in my experience Japanese aftermarket stuff is pretty good quality-wise.   The above site allows overseas buyers to purchase stuff more easily from Japan but there are fees and shipping costs, of course.   The original Japanese seller page is here: https://auctions.yahoo.co.jp/jp/auction/p1197401228 Copper/Nickel is fine but I still prefer bundy tube and it's also cheaper.
    • Your chihuahuas look weird!
