Hi all,
I am organising a dyno day out at Power Tune Australia in Villawood.
It will be on a Sunday 6th November and about $50 for 3 power runs etc..
Just wanna see who's interested.. pls reply to this post.
Btw- It's a 4WD dyno, GTR & GTiR people can come too!
The day will start at 9am till late.. Come early to reserve your spot.
Cheers.
Edited by mac30
https://www.sau.com.au/forums/topic/91217-dyno-day-power-tune-australia/
Sorry for late reply guys. From memory I think its was a dyno dynamics dyno but I can enquire to find out exactly.
N1GTR - dyno starting at 9am so plenty of time before ur off to work.
It be good if I can get some sure numbers on skylines or any other turbo cars who wants to participate that way the event can be organised smoothly and least waiting time.
Hi ALL,
Apologies for late reply once again as I've been quite busy with work.
To answer all ur questions:
* A/F ratio readout will be provided
* print out of the highest power run will be given or whichever requested by customer
* Power Tune is located @ 8/88 Seville St, Fairfield
We have also planned for a bbq and drink on the day and a showcase of HKS products and screens of power runs.
So far the turn out is very positive with a range of cars on the list so if anyone wants to be on dyno early I suggest they come early and put your name on the list. A lot of effort is put into the planning side so we will try and make this as smooth as possible.
Thanks for all who has shown interest and would like to see most of u guys there.
Cheer
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
