Item: R33 GT-R water pump
Item Condition: Brand new
Reason for Selling: dont need it
Price and Payment Conditions: $120
Extra Info: as far as i am aware, will fit an R32 RB26 but requires 1 hole to be plugged and a new hole drilled
Contact Details: PM or email me at [email protected]
Item: Genuine Momo steering wheel
Item Condition: used
Reason for Selling: dont like it
Price and Payment Conditions: SOLD
Extra Info: its small
Contact Details: as above
Item: R32 GT-R stock fuel pump
Reason for Selling: upgraded
Extra Info: in perfect working order
no pics
Item: R32 GT-R Whiteline front strut brace
Price and Payment Conditions:SOLD
Extra Info: Apexi sticker on it
Item: R32 Trust dual gauge holder
Reason for Selling: wont fit with roll cage
Extra Info: will swap with a good condition single gauge holder for R32
Item: Power FC Hand controller for R32 GT-R
Reason for Selling: bought it off another forum member but never tested it on mine. its not compatible with mine
Extra Info: Because i am unsure of the specific model for the GTR PFC needed, its best you try it out before you buy it ie no point interstate posting
Item: Standard R32 GTR front seats with rails
Reason for Selling: Changed seats
Price and Payment Conditions: $600
Extra Info: wear in drivers side bolster
Edited by [WLDCRD]
https://www.sau.com.au/forums/topic/91222-fs-gt-r-stuff-in-melbourne/
Glenn is the dual-gauge holder the replacement part for the a-pillar like the GReddy one? I'm guessing it is because that's why you want a single, but would like to check first! :(
Mark
mark,
yeah it is. its the ones that you gotta screw in!i dummy fitted it today with the cage front arm and it wont sit properly. so i gotta change to a single. btw, i still havent called them about that mud flap thing yet! haha
glenn
  • 3 weeks later...
hello there
I have a r33 series 2 GTS-T.
do you sell the
1. front lip
2. rear speaker bracket
3. the cover that covers up the battery compartment in the boot
please  let me know. thanks
sorry anexiole, i am not stripping a car so i dont have those parts. i also dont own an r33. sorry
  • 3 months later...
  • 1 month later...
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
