hey...
im chasing a right hand side tie rod end for a 1989 R32 gts-4... my mechanic has told me that the one on my line is f#$ked :( and needs to be replaced asap... so if there is anyone out there that knows where i can find one or someone that is wreckin a R32 and would have a spare one of these i would be very interested... :)
cheers
chard
https://www.sau.com.au/forums/topic/91403-wtd-tie-rod-end/
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
