- Factory upgrade 10 stack CD player with seperate din head unit which controls the stacker off an r33 s1 skyline - $20
http://img390.imageshack.us/my.php?image=stacker6bh.jpg
- stock r33 series 1 radio headunit ( has wiring loom and all ready to be hooked up) - $15
http://img292.imageshack.us/my.php?image=s...3s1radio5rw.jpg
- also have r33 passanger sun visor with a small rip - $5
- brand new chrome silver with blue LED bonnet water squirter thingos - $10
all items are in working order, and in genuinely good condition
i can post anywhere in aus as long as buyer covers expenses
https://www.sau.com.au/forums/topic/91520-stuff-for-sale/
The factory head unit is simple, bcos you car should already have the wires there, its just a matter of hooking all the colours back up. The CD stacker headunit as shown on picture next to the actual stacker goes in the other din and thats wat controls the stacker, hooking that up is a bit more tricky as the wiring for it is still in my car and a bit of a bitch to remove.. however your car might already have the wiring i'm not sure thou.
i'm located in melb if u wanna check it out
pm me
https://www.sau.com.au/forums/topic/91520-stuff-for-sale/#findComment-1654573
  • 3 weeks later...
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
