Item: 1997 Nissan Stagea, Red, auto RS4 4WD, 2 sunroofs, cargo barrier, 2.5litre turbo, wind deflectors for windows/sunroof climate control etc
Item Condition: Car is in great condition, slight scuff on passenger mirror
Reason for Selling: It is my fathers car, I imported it from Japan for him to replace his Ford Falcon, however he has taken my delica instead so he can tow around his dog trailer etc.
Price and Payment Conditions: Asking price is $17500 but is negotiable, want the car gone ASAP
Extra Info: I will go up there and take some pictures of the car on Saturday and host them
Contact Details: you can PM me here or contact my Dad direct on 0418 295 675
Thanks
Lee
Edited by nfs13b
https://www.sau.com.au/forums/topic/91531-red-1997-stagea-fs-17500/
  • 5 weeks later...
Hey All,
Car is still for sale, I will try to host the pics tonight, I am after a quick sale so I am dropping the price to:
$16000
Now for a 1997 model thats a pretty good price.....
http://www.skylinesaustralia.com/forums/in...topic=83567&hl=
interested in a trade at all?
we need to part with this and buy a 4 door someting.... quite keen on stageas!
Hey,
Sorry but we are not looking for another car, good luck with the sale though.
Stageas are nice cars and this one is a pretty good buy i think.....
  • 3 weeks later...
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
