Hey this is a group buy for LINK ems ecus
I have arranged with LINK ems in NZ to buy 10 units with them at 750 each including postage costs to australia.
If we dont not get 10 people we must have at least 5 but the price will go up by about $50
these are the models that I can get
Honda .
IntegraLink 1992-5 B18C Integra. Not G3
IntegraLink 1996-8 B18C Integra. Not G3
CivicLink 1992-5 B16 Civic. Not G3
CivicLink 1996-8 B16 Civic. Not G3
CivicLink 1999-0 B16 Civic. Not G3
Nissan
GTSLink R32-R33 Not G3 (Includes MAP)
Subaru
PossumLink RS RS Legacy / Liberty Not G3
PossumLink V1 &V2 Impreza WRX (MY93 - MY96) Not G3
PossumLink V3 & V4 Impreza WRX (MY97, MY98 & 22B) Not G3
PossumLink V5 & V6 Impreza WRX (MY99 & MY00) & Forester Not G3
these units do not come with a hand controller but they can be supplied for an extra 250 per unit if needed
CLOSE DATE 10/11/2005
These products can be pickup from me when they come in from NZ or I can re-send them to you for 10 bucks
https://www.sau.com.au/forums/topic/91652-link-ems-group-buy/
Tuning
There is no need for the vehicle owner to understand, or even be aware of, the “zone sheet”. This page is for the those who tune engines or are interested in the more technical aspects of engine management. The zone sheet is the table which the Engine Management System looks up in order to run the engine satisfactorily. All settings reside here and are adjustable via the Remote Tuning module. In order to adjust fuel for example there are three controls:
MASTER Controls overall fuel injection scheduling and is effective throughout the entire operating range from idle to full power. The scale ranges from 0..99, the higher the value, the greater the overall fuel.
ROWFUEL Allows the ZONE FUEL table to be adjusted a whole row at a time. i.e. All values on the current row will be adjusted up or down irrespective of the RPM. ROWFUEL is primarily intended as a coarse adjustment to allow broad shaping of the ZONE FUEL table during initial tuning, and would normally be used after MASTER has been set, but before ZONE FUEL is used. Careful use of ROWFUEL will eliminate the need to spend large amounts of time in ZONEFUEL trying to make major changes overall by wandering about the table making localised corrections. (It is quite difficult to hold the engine in any one of 96 zones while corrections are made even under the most favourable conditions.) The current row is displayed in parenthesis to show the currently active row, but the RPM information is suppressed since this feature is not RPM dependent.
ZONEFUEL There are 96 fuel zones arranged in a rectangular grid consisting of 6 rows by 16 columns. The rows progress in steps of Manifold Air Pressure to provide the “load” axis, and the columns progress in steps of RPM. Therefore, each zone represents a unique engine operating condition allowing fuel changes to be made in small, localised areas. The selection of zones is completely automatic, depending on the actual RPM and MAP values at that instant. The current (active) zone is identified to allow correlation to the zone sheet and to give an indication of where you are in the table. The zone numbering system is not linear, but designed to provide a clearer indication as to effective location. e.g. zone 110 = ROW 1, 1000..1500. Adjustments are made by operating the “Adjust” buttons as required, and the actual value is displayed on the right hand side of the display. Adjustment scale = 0..99
Large steps between zones are permitted since the Link Engine Management System interpolates (i.e. calculates intermediate values) on all tabled data. The 96 adjustable zones effectively become 32,000 micro zones after interpolation.
  • 4 weeks later...
    • No, you're wrong, and you've always been wrong about this. The Nismo has 2 sets of openings. One is a real 2-way, and the other is a 1-way. There is no 1.5-way possible with the ramps that they offer. A real 1.5-way does exist. That Cusco stuff I posted is a prime example. If the forward drive ramps are, say 55°, and the overrun ramps are, say, 30°, then you will get about half as much LSD effect on overrun than you do on drive. It is real, it realy works. OK, you're slightly right. The Nismo has 55° and 45° ramps on the 2-way, so it does offer less LSD effect on overrun. But, I think that just means that they've (probably) sensibly established that you do not want actually equal LSD effect on overrun. You just want "quite a lot, but not quite as much as the drive LSD effect".
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
