just trying to take off my intake pipe so i can get to the sparkies under the cam cover... and one of the bolts on the intake pipe wont come out so i cant remove the pipe!
screwdriver a million times, doesn't come out...
ratchet a million rotation, doesn't come out...
pliers, twist and pull up, doesn't come out...
the screw will turn, but it doesn't come out!!! it just turns and turns forever...
looking underneath the screw, the teeth of the shaft look perfect so i dont understand why its not coming out...
im getting pissed at this bloody screw, but im gonna stop before i lose the entire head of the screw...
any ideas how to get it out!?
https://www.sau.com.au/forums/topic/9200-stuck-screw/
Guest Boxhead
it could be a little rust that is stickin inside the the nut...
my grandfather(ex mechanic) tought me this, tap it with a hammer, not too hard but a half decent way.. maybe a couple of times, then use wd40 with the extender part to try and get it inside were it screws in.. let it sit . then try again
https://www.sau.com.au/forums/topic/9200-stuck-screw/#findComment-138036
coco69,
Sounds like the thread has stripped, have you tried using a flat blade screwdriver under the head (or the intake pipe) and twist to produce a upward pressure on the head (if you can get it under the head) at the same time as you try to undo it?
might work!
MEGA
https://www.sau.com.au/forums/topic/9200-stuck-screw/#findComment-138064
yeh, thanx for the replies guys...
tried both really...
tapped it lightly and greased it...
and also been wedging the screw upwards and pulling it up while twisting... doesn't budge... just keeps on turning and turning...
bought a screw extractor kit for like 9 bucks...
but gonna hafta drill thru the screw, so it'll wait till tomorow. :(
https://www.sau.com.au/forums/topic/9200-stuck-screw/#findComment-138097
coco69,
Screw extractors only work when the screw/bolt/stud head is broken off they weren't designed for what you wan't to do! as they are only a means to grip and turn the screw/bolt/stud anti clockwise which you don't seam to have any problem doing by the sounds of it! But you still might have to drill the old screw out and then tap a new thread!
MEGA
https://www.sau.com.au/forums/topic/9200-stuck-screw/#findComment-138148
mega, i thought screw extractors also cause the screw to climb up the extractor bit as its turned anticlockwise?
i get what you mean, i dont wanna open up the kit if its not gonna work, otherwise i can't return it and get my money back... hmmm...
bloody RB's with their gay intake pipes over the cam cover!!!!!!!
this is the only time in my life i actually wish i had gay 4cyl sr20... bloody intake pipe... >:(
https://www.sau.com.au/forums/topic/9200-stuck-screw/#findComment-138244
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
