Are there any Skylines here?????
I'm in Hobart and I have an R33 GTR, there are probably 4 or 5 others here (maybe more, I don't drive around the city much). There are quite a few other R33's around.
From what I've seen, Skyline owners don't go out of their way to stay in touch with each other down here (although someone did wave at me from an R31 recently). I guess there aren't enough to make it an active community, unlike other groups.
What abt fuel, is 98 octane fuel easy to get? I was thinking to bring some Octane booster from here, but seeing the tight security measures b4 boarding the ship might cause a hassle if you bring some flammable material in your car...
2nd, any of you went to Tahune Forest Reserve (where the airwalk is), I read that it's unsealed road, can drive a RWD skyline there or better not and get a 4WD?
98 is next to impossible to get. It can be done but in your situation forget it pretty much. A few cans of booster is the best you can do.
More pressure is needed on the fuel companies and the Government. The RACT down here is no help, one of their spokesmen has been quoted as saying that high quality fuel isn't needed down here.
Tim.
I also need the following travelling times (just estimate):
1. Devonport - Deloraine
2. Deloraine - Launceston
3. Launceston - Hobart
4. Hobart - Geeveston
5. Hobart - Port Arthur
Any help will be appreciated...
My standard R33 GTR has had no problem with any 95 octane fuel I've put in it except for Caltex which has proven time and again to be utter sh!t.
I have imported some Optimax for my track car which I occasionally use to fuel the GTR.
As for the other question about travelling distances most of them would be an hour or under except the Launceston-Hobart leg which is about 2 hours. All at around the speed limit. It's not far to anywhere here. :-)
Tim.
Hey Tim,
what abt the arve river rd (I think that's the road name) going from Geeveston to the Tahune Forest Reserve Airwalk... I read from books it's unsealed road... will it be ok for a RWD coupe to pass thru? Hope 4WD not mandatory.
thx
Rianto
I haven't been to the airwalk and it'd be a long time since I've been in that area so I can't help you directly.
I have asked someone who's been there who says he thinks it's sealed all the way but isn't 100% sure. I suggest that seeing as that was his response that if it wasn't sealed it must be in pretty good nick.
Tim.
mate i can give you the times as i lived in tassie for 24 years
1. Devonport - Deloraine 30 minutes
2. Deloraine - Launceston 30 min
3. Launceston - Hobart 2 hours
4. Hobart - Geeveston 45min
5. Hobart - Port Arthur 90min
if you go hope you have fun
implanning on going back hojme for 2 weeks at easter, i cant wait as i had a ricey lancer when i left. When i return im driving a R32 GTST with 190rwkw.
  • 4 weeks later...
Guest Method
Hey Tim,
thx
Rianto
Ive been down to the airwalk, im pretty sure I had my front wheel drive lancer coupe then and it made it in and out without a hassle.
Good News for me:
Looks like I will be visiting Tasmania after all these years....
Plans are mid May 2003, I know it may not be the best season to go as it's approaching winter, and the climate may be wet and cold, but better than never go....
Bad News for me:
I won't be driving my Skyline, will be going with my old folks. We'll fly to Hobart then rent a little Lancer (I book for a manual one, hope they give me the right one, hate the autos in Lancer). From there we will be travelling around and making our way north and return to Melbourne via Launceston. But hey one of my previous car was a 93 Lancer, so I know they're pretty ok car in a manual form.
Bad News for you:
And if you think of asking "Rianto, can I borrow your 'line while you're away?", the answer is "No, not in a million years", then you say "DOH!" :(
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
