Hi all..
Just curious if anyone has a Gear shift for sale for an R32 (rb20) gearbox?
Also the little boot at the bottom which hugs over the top of the box..
Mine has split and oil is leaking thro the boot.
Plz PM me if you have anything.
Thanx heaps:)
Andrew
https://www.sau.com.au/forums/topic/92226-r32-gear-shift-stick/
hey mate i have neither part your after but if its the rubber boot that goes directly ontop of box its a genuine nissan part available through your local holden dealer at the high price of about 16 dollars usually available over night! (same as vl commodore)unless the rubber boot your refer to is the one with the metal ring around it then just try wreckers.
Hi all..
Thanx heaps:)
Andrew
You could always buy a short throw kit for about $60 and just replace it with that instead.
If you need info on where to get one, send me a PM
Cheers B
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
