Item:
2 x R34GTT specific Child Restraint Compliancing Kits
(far left and far right kit, I am retaining the centre one)
Sydney Northern Beaches or CBD
Item Condition:
Installed for compliancing for less than 5 months... still got stickers on them from the compliance shop.
Reason for Selling:
Installed some new rear speakers, had to take two out of three of these things out. Yet to find out whether it is legal to only have one mount instead of three.
Price and Payment Conditions:
$15.00 each + postage
$25.00 for the lot + postage
Extra Info:
Nothing else really...
Contact Details:
PM or Post to show your interest, I will reply ASAP.
Photos for your viewing pleasure.... and I had a thought about this; the only people who would seriously be interested in this would be compliance shops LOL - but anythings worth a shot :D
Photos for your viewing pleasure.... and I had a thought about this; the only people who would seriously be interested in this would be compliance shops LOL - but anythings worth a shot :)
no not even complaince shops ....the other half of the bracket isstill pop rivited to the parcel shelf...just leave them in the car boot for the next guy ..he might have 3 kids ;)
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
