Help The Young Padawan!
Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
By GabsReDeal · Posted
In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition). -
ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
OK, if it idles at 1000+ with the AAC, its not an idle airflow problem. The cold start valve just gives extra air when the engine is cold, but you have enough air without it to idle at 1000. I think you are back to a fuel problem, sorry. Can you see the fuel pressure staying constant or does it drop as the revs drop to a stall?
By RB25inside · Posted
Well, I was using ECUTalk software if that helps? Not sure if that only can see engine codes? Is there any other software I could give a try? Or any way I can get a blink code?
