Recently Bought Series 1 R33, And Was Given Both After Market And Stock Exhaust Sytem.
Due To Only Needing 1, The Stock Exhaust Is For Sale.
*Item Condition: OK, Pics Available On Request
*Price and Payment Conditions: Make An Offer, Will Also Be Interested Swap/Negiotations With Other R33 Parts (GTR Wing,Wheels)
*Extra Info:Pictures Available On Request
*Contact Details:[email protected] Or Through SAU
https://www.sau.com.au/forums/topic/92523-r33-series-1-stock-exhaust-system/
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
