Originally posted by infected flow
still no sleep -----rrrrrraaagggggeeeeee.......(whitney houston special)
starting to see two of everything , It was a good night had by all this probably has to be one of the biggest turn outs that ive been to. one more thing  (hey nick & donnie im pretty sure that the impeller blades from that turbo are plastic and then foil tipped) ..rrrrrrrraaaagggggeeeeeeeee!!!
we want pics!!!!! we want pics!!!!
  • Replies 178
I'm just making a gallery of higher res pics now (800x600) with just the ones that turned out alright, enhanced a bit and numberplates bleeped etc. Will probrably upload it tommorow, as there's alot of pics to edit.... I'll also add in your pics Silver Arrowz, If you wanna e-mail the rest to me ([email protected]) i'll host 'em for you so you don't have to bug your friend about webspace. I've still got like 25mb left so it's no trouble =)
Guest ManNGolf
Originally posted by [ryan]
Man'n'golf - I was using time exposure to substitute for the flash.. It actually comes out alot darker with the flash for pics of things more than about 1 meter away!
I saw you giving your golf some after we left EC -- nice nice.. goes along quite well!
*takes a bow* i do try my best to not get in the way of a skyline? :P hehehhehehhe
was only making up for not karting actually. the track organisers didnt let me take my golf on the track even though i was in the same HP category 13HP....... :P
hahaha thats funny stuff........i heard there was a ram raid at fairfield.........you guys probly too busy chatting to have noticed.
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
