Your topic for the ad was VG30, that can easily be misinterpreted to beleive it was VG30DET or VG30DETT.
All I knew is that I wanted the VG30 turbine housing which was larger than my RB25 for a hi-flow and I told you that but you didn't have a problem taking my money and then basically tough luck you can't have it back now.
I didn't know what to look for when buying it other than the larger turbine housing and with the dump pipe and heat shield on I couldn't see that.
Now it's just gotten to the point that you knew what my plans were for it and that it would be useless but you still took my money and refuse to give it back.
Is that how someone should trade on these forums?
If GCG (with their experience in turbochargers) are wrong about this one (as one person thinks) and it is in fact a VG30 then I will personally give the turbo back to the seller (he can keep my money as the turbo is useless to me) and he will have a true honest apology!
Im still waiting B)
Im sorry to say but your clueless as f***.. You've seen for yourself the handful of people on here who "think" they know it all.. leave modifications as such to people who know what there on about (someone like GCG :lol:)..
end rant!
Edited by nuR.spec
end rant!
look mate, you've knowingly farked this guy over and yes he may have been naive in thinkin that all people around here are honest and helpful, but get over yourself.
you sold him a useless turbo, fair enough, thats between the two of you to sort out.
but getting on here and rubbing it in and giving crap to GCG is not gonna impress anyone.
random preson with 38post V's a SAU-Vic member,
gezz i dont even need to read the thread to know who is in the right and who is in the wrong.
Presa, i think u should pm blitz or prank and informed them of what has happen so they can ban this f**khead or watever they find fit
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
