  • Replies 65
yeah whast the go with this cruise.
im up for it i thinks...
i think we all should maybe meet 30mins prior or something before the main meet thing..
ah whatever, im woffeling...
lol
lol
I'm wanting to go, thats for sure. Trying to change my work shift for a 4.30am start and finish at 8am on sunday instead of doin 8am-12pm for work.
A meet 30mins prior to the cruise would be good as well.
Saturday nights cruise we just had was a pretty good one. Nothing blew up so I'm happy!!
Anyone notice how high that chick almost jumped when the BOV went off along the esplanad on saturday night when cruising?
I seriously couldnt stop myself from laughin when I saw that.
Friends further up were paying out on her screaming "You just got scared by a skyline" and they were all laughing.
here you go killa all the info you need about this weekends cruise and YES to ska im there with bells on
ummm.... I think you got the wrong cruise there.
there is a nissan cruise this sun, nov 6th.
http://www.boostcruising.com/forums/index....showtopic=96463
dont think the club empire one is going to be all that successful. after all, nissan people rather cruise with other nissan ppl then a mix cruise I would think.
Ska.... did u notice that chick along the esplanade that almost jumped when I let the BOV off? Pretty sure u were right behind me at the time.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
