hi all bought this kit with a complete engine package about 2 months ago rb25/30, done maybe 25kms on it since bought...
all parts are in great condition, turbo has ZERO shaft play i checked it out when the whole motor was out of the car.
kit consists of;
Trust TD07S turbo with T04R compressor wheel and T66 rear wheel with 360 degree thrust bearing
Trust Tubular Exhaust manifold Low mount for stealthier look, stainless
Trust 45mm external wastegate
Melbourne Autosalon car made 352rwkw@16psi off previous owner
not very laggy at all
got a package off a friend for a hi mount brand new turbo with more power so thats the reason for selling...
Staying pretty firm on 1700 for the LOT!
can supply pics
ben...
Edited by 2BNVS
https://www.sau.com.au/forums/topic/92841-eoi-turbo-kit-for-sale/
kit consists of;
Looking for somewhere around 1700 for the lot
can supply pics
ben...
h
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
