LATE UPDATED POST - SORRY! TEINS ARE SOLD
Hi Everyone, I have my TEIN HA's for sale. Front & Rear coilovers & TEIN Springs (+Tein Strut Tops).
All are in Great (VERY GOOD) Condition. I have just had the full Whiteline/Bilestein set-up (From SydneyKid's group buy) installed, so these are now for sale.
PRICE: - $500 for the lot. Pick up (Melbourne Buyers prefered), but I am willing to post at buyers expense. I am located in Mooroolbark, VICTORIA.
I also have STD R33 GTS-T front & rear Swaybars for sale. ($30 each or both for $50). +POSTAGE Both are in excellent condition.
Lastly, I have 4 (2 rear/2 front) STD R33 GTS-T Shocks & springs. (BUT - They do not have the strut-tops, as I had to buy these because of my TEIN strut-tops were no good for my Whiteline Springs). All in excellent condition, although missing strut-tops.
Price - $40 each or $100 for all 4 shocks/springs). + POSTAGE.
Everything will fit a Series 1 or Series 2 R33 GTS-T. All parts - except for the STD stuff which is off a series 2, are from my 1995 R33 GTS-T (series 1.5).
If anyone wants everything, please call me on 0404 323 989 or PM.
Cheers,
Chris. :P
https://www.sau.com.au/forums/topic/93073-fs-tein-ha-front-real-coilovers/
very interested in your tien's. im in adelaide, id be greatly appreciative if you could find out approx. postage cost to get it here.
I will get back to you with a postage cost
Cheers
Cheers,
Chris.              :D
Hey mate, i urgently need some std r33 rear shocks with no springs. I have a s2 so they will fit yeh?
also what condition are these shocks in? any leaks etc?
Let me know asap.
Thanks, Mike.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
