IT RUNS, OMG, DOES IT EVER RUN!!, WILL HAVE IT ON THE ROAD IN A FEW DAYS!!!
Hello again gents.
I have a mystery of a problem here. Bit of a long explanation but here it goes:
I have a 1990 S13 240sx with an R32 RB26DETT in and running.
I have the turbos, intercooler, and piping temporarily run with PVC. It's sufficient for plumbing design, fitment, and testing. I have built a downpipe to keep the stock twin turbos which is connected to a full 3" exhaust.
I do have several vacuum/pressure lines unhooked, however they are plugged (not well mind you). I have not hooked up a boost regulator or the BOV's yet. Better to get the motor running well first before worrying about getting that worked out.
When the AFMS are unplugged the motor starts at the turn of a key and runs rather well in "limp mode." It's rpms settle in around 2200 most of the time, sometimes around 1600. The motor responds to the throttle by idling down further. It is ofcourse running overly rich to the point it stings your eyes a bit (I figure this is normal as the engine will dileberatly run overly rich to prevent internal or turbo damage). At no point can I get the motor to go over 3000rpms, once again this seems normal for not having AFMS plugged in.
O.K. now the interesting bit:
With the AFMS (stock r33 ones thanks to HUNGRY 6) plugged in the motor will start, but only up to approx. 800rpms before immediately shutting down. The same goes for having in combination either AFM plugged in one at a time. As well as, with the engine running, if I plug in one AFM the motor will sputter for 1/2 a second and then shut down.
I am beginning testing of the wiring harness and other sensors however this process is tedious and even the solution can be overlooked. I have tested the fuel pressure and it hits pretty close:
Test ....................Standard........Actual
Ign. On ..................43psi .......... 40psi
Idle .........................36psi .......... 39psi
Idle w/o vac line.......43psi .......... 45psi
Here are my thoughts:
In "limp mode" (am I calling it right?) the ecu gives me a set amount of fuel and timing, without knowing how much air is coming in, it's ignoring most of it's other sensors.
When the AFMS are plugged in the ecu then attemps to set the correct air-fuel mixture and appropriate timing. Some other sensor (now that it's out of limp mode and being monitored) could be giving faulty information causing the motor not to run.
Or, something else is seriously wrong and ignored in "limp mode," hence when the AFMS are plugged in the ecu responds by killing the motor. i.e. Faulty ECU or Knock sensor.
Also, it's probably not something tuning related, i.e. bad O2 senors, boost/vacuum leak, etc... I believe these sort of issues would cause it to run poorly, not necessarily shut down the motor.
There are a world of things to test for, however I'm hoping that someone with a little more experience with the RB series than I (which would be none) could help point me in the right direction as I am pretty well stumped here.
Any thoughts no matter how small or seemingly trivial will be helpful. Our collective brain storming might get me going down the right road.
THANK YOU, THANK YOU in advance, This is a full 1 year prodject nearing it's completion and I am beside myself trying to get it finished.
P.S. located in the middle of the U.S.A. there are virtually no tuners within 5hrs of here that have ever seen an RB motor.
Edited by RB240Dav
With running the RB25 AFMs, What sort of ECU are you running?
if you are running the standard ECU without any extra calibration (SAFC or other) you will not get it to run.
However I would be guessing you are running a PFC?, if so have you selected the correct AFM's on the PFC?
:P hope this helps...
The reality here is you most likely have a whole host of sensor/wiring problems. Limp home means nothing more than 2,500 rpm. In fact "limp home" is a bit of an overstatement, more like "limp to the side" of the road".
The best diagnostic tool I have is the Consult interface, I guess that comes from years of reliance on the Power FC Commander. They let you see, in real time, the inputs from the sensors which makes fault finding so much easier.
There are a number of them available on the forum;
I just ordered one of these, I like making up kits
http://www.skylinesaustralia.com/forums/in...showtopic=92853
If you don't want to make up a kit, I have used one of these a number of times and they work great;
http://www.skylinesaustralia.com/forums/in...2617&hl=consult
I haven't used on of these, but plenty of guys have;
http://www.skylinesaustralia.com/forums/in...showtopic=92105
Without one of these you are going to spend hours with a multimetre chasing around the wiring looking for an answer. A Consult interface will help you find it in minutes.
Hope that was of some help
:) cheers :)
Well, this is about to become one hell of a learning experience since there is no easy way out.
It's time to get down and dirty, and I'll let you chaps know what I find.
I'm sure you hear it a lot SK and I hope you never get tired of it. . .
THANKS.
I want to run a code check on my ecu by counting the l.e.d. flashes on the ecu, but I have a Nissan Remanufactured One, and for some reason it doesn't have any lights or dials on the back of it, WTF!!
So anyways, I know that you can also count the "check engine light" flashes. I'll splice into the wire coming from the ecu to the light but I don't see a "check engine light" on the instrument cluster I've got (it's not installed) What light flashes?
Yep, most of the ecu's don't have lights, I kinda figured you wouldn't have a GTR dash in there for the "Check Engine" light to flash codes for you. That's one of the prices you pay for an engine swap. Hence why I suggested the Consult interfaces.
Pin #32 is the output from the ECU to the dash warning light, so try wiring a 12 volt 1 watt globe there, if you can't wait for a Consult to arrive.
:) cheers :)
I remember reading about two wires you short (if you have the diagnostic connector you can jump the pins) in order to get the ecu to flash the codes to the dash. I can't seem to find the thread now, anybody know if I'm on the right track again?
SILLY SILLY QUESTIONS.
Thanks again SK
IT RUNS, IT RUNS, IT RUNS!!!!!!!!!!!!!!!!!
There was a break INSIDE the wiring harness (damn importers don't know how to properly pull a loom)
I was wiring up the check engine light to run the codes. So I had to move the harness around a lot, plugged in the mafs. Gave it a turn for the hell of it, and it started, and ran.
OMG, IT SOUNDS SO GOOOOD!!!
THANK YOU ALL!!!!
Good to see you got it up and running, have fun with it.
In those pics youve got quite a car yard there, is that a FC RX7 in the background?
Thanks,
yeah it's an FC. Rather unfortunate incident for the owner, poor guy. . .
It was near mint and he stored it in the winters. (he's 23yrs old) So he pulled it out of storage this spring, started it up and ran out of gas about a mile down the road. Was gone for 15 minutes to get more gas and when he came back the fire department was there putting his car out. The battery cracked and leaked acid onto the harness underneath all winter long, and then wham, catches on fire. Thankfully it went up on the road and not in storage where there were 2 other rare cars. He's going to work on wiring it back up this winter, as you can see, he already replaced the panels.
The motor just screams, I should have it rolling in a few days, just have to finish the intake, brakes, alignment, and install driveshaft. All the tracks are closed, so I'll have to find someone with one of those G-Force tec thingies to get a 1/4 mile estimate.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
