Item:Samsung I-mode Phone S342i
Item Condition:Opened, but brand new
Reason for Selling:Unwanted gift
Price and Payment Conditions:Bank Deposit / COD postage at buyers cost/B]
Extra Info:Comes complete as was opened
Contact Details:PM me or sms me
0414205047
Darks
https://www.sau.com.au/forums/topic/93372-samsung-s342i-telstra-phone/
how much do you want for it and is it locked to a sim card????
Hey mate,
$240.00 will do. (postage included)
please call me on 0414205047 if you want it as i have advertised elsewhere.
Not locked, pics i can get. please PM your email address and i will pass along.
Although, it is a new phone so there is minimal wear (only a few light light scratched on battery)
any pics?
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
