MRK25T Posted January 27, 2003 Share Posted January 27, 2003 I'm thinking about getting come HPC coating done and want to do it all in one hit. For me the HPC will serve 2 purposes: 1. reduce heat since i'll be running a bar or so of boost 2. It looks good. What should I have done to cover both bases? Will it give me a increase in performance? What parts should I polish instead of HPC? Lastly, i've never seen any pricing on HPC coating. What will it cost? Mark Link to comment https://www.sau.com.au/forums/topic/9341-hpc/ Share on other sites More sharing options...
sidewaymambo Posted January 27, 2003 Share Posted January 27, 2003 bump..consider I like to know the price and where as well.. Link to comment https://www.sau.com.au/forums/topic/9341-hpc/#findComment-140490 Share on other sites More sharing options...
GTS-t VSPEC Posted January 27, 2003 Share Posted January 27, 2003 Hi Guys, I was looking at getting my exhaust manifold coated so I gave these guys a call, it's about $550 to get the exhaust manifold coated. If your after serious performance then you should ceramic coat the exhaust manifold and turbo exhaust housing. HPC coat the intercooler pipes, most important is the intake manifold pipe. I think that with a combination of HPC, cold air induction you will see a decent performance improvement due to the cooler intake temperatures. Don't forget that heat wrapping will provide similar results, but it doesn't look as good. See'ya:burnout: Link to comment https://www.sau.com.au/forums/topic/9341-hpc/#findComment-140502 Share on other sites More sharing options...
sidewaymambo Posted January 28, 2003 Share Posted January 28, 2003 I'm new to this process, but I understand the advantage of HPC and ceramic coat ( I always though that hot gas will run faster..), however does ceramic coat can apply on "any" surface? for example, I have a set of trust stainless manifold and mild steal..dump + front pipe, should I ceramic coat the them? or just the manifold? I know the heat warpping, but does it capable to handle 1200+ temperture? thanks.. Link to comment https://www.sau.com.au/forums/topic/9341-hpc/#findComment-140723 Share on other sites More sharing options...
Ronin 09 Posted January 28, 2003 Share Posted January 28, 2003 I've just ordered a stainless dump pipe, and have a Trust mild steel front pipe. I called HPC (www.hpcoatings.com.au) last week and the guy quoted me $66 per foot for piping. I figured that because hot gas travels quicker, and the next main restriction is the cat, that this would be enough of the exhaust system to do. PS they need 5 days to do the coating. Link to comment https://www.sau.com.au/forums/topic/9341-hpc/#findComment-140896 Share on other sites More sharing options...
GTS-t VSPEC Posted January 28, 2003 Share Posted January 28, 2003 sidewaymambo, You can ceramic coat just about any metal surface, if it has already been used then they will need to clean it and bake it so that the ceramic coat will stick. Ceramic coating is best for exhaust manifold, dump pipe, front pipe and turbo exhaust housing. I think if you want to do intercooler pipes then either use heat wrap or HPC. The heat wrap will work fine in high temperatures like on your exhaust manifold, just make sure you buy the right stuff, and not some cheap brand. See'ya:burnout: Link to comment https://www.sau.com.au/forums/topic/9341-hpc/#findComment-140901 Share on other sites More sharing options...
sidewaymambo Posted January 28, 2003 Share Posted January 28, 2003 Thanks guys, will give them a ring, and see what happen.. cheers, Link to comment https://www.sau.com.au/forums/topic/9341-hpc/#findComment-140965 Share on other sites More sharing options...
Guest INASNT Posted January 28, 2003 Share Posted January 28, 2003 how much per meter is the good heat wrap worth? Link to comment https://www.sau.com.au/forums/topic/9341-hpc/#findComment-141321 Share on other sites More sharing options...
GTS-t VSPEC Posted January 28, 2003 Share Posted January 28, 2003 I think you can wrap an entire manifold for about $60-80, from memory. A much cheaper if less attractive option. You can do both, and it works even better. See'ya:burnout: Link to comment https://www.sau.com.au/forums/topic/9341-hpc/#findComment-141469 Share on other sites More sharing options...
torana_mad Posted January 28, 2003 Share Posted January 28, 2003 Im thinking about doing my extractors and intake manifold but i guess i can see how you guys go 1st now Link to comment https://www.sau.com.au/forums/topic/9341-hpc/#findComment-141667 Share on other sites More sharing options...
MRK25T Posted January 28, 2003 Author Share Posted January 28, 2003 Keep me up-to-date on any quotes you get for the HPC coating. What sort of performance gains would I realise if I get the exhaust manifold, turbo exhaust housing and intake manifold pipe as VSPEC suggested? and has anyone got any ball park figures for this work - I cant call them while i'm at work. I might leave them an email instead. Mark Link to comment https://www.sau.com.au/forums/topic/9341-hpc/#findComment-141718 Share on other sites More sharing options...
phat32 Posted January 28, 2003 Share Posted January 28, 2003 hey guys, instead of ppl saying i will c how much it costs, why dont we all pool out resources and get a large group to go down there and hit them for a group discount, huh sound like a good idea....... well thats my 2 cents worth? Steve Link to comment https://www.sau.com.au/forums/topic/9341-hpc/#findComment-141876 Share on other sites More sharing options...
torana_mad Posted January 28, 2003 Share Posted January 28, 2003 Sounds good to me. Link to comment https://www.sau.com.au/forums/topic/9341-hpc/#findComment-141884 Share on other sites More sharing options...
Ronin 09 Posted January 28, 2003 Share Posted January 28, 2003 I'm with steve. If we can organize a group 'coating' maybe it will be cheaper. I will call them tomorrow and see if they will do a group discount, and if so start a new thread and will try and organise it with HPC. Not sure how we can logistically do it - send all parts to me and then to HPC? or send them individually? If i organise it probably keep it to the Vic boys and girls, just it is easier than doing everywhere. I will keep you posted, check here and if i start a new thread i'll link it to here. Link to comment https://www.sau.com.au/forums/topic/9341-hpc/#findComment-141955 Share on other sites More sharing options...
sidewaymambo Posted January 29, 2003 Share Posted January 29, 2003 well, if we can manage a group discount, how to send to the place won't be the problem.. Link to comment https://www.sau.com.au/forums/topic/9341-hpc/#findComment-142201 Share on other sites More sharing options...
Ronin 09 Posted January 29, 2003 Share Posted January 29, 2003 Guys, spoke to HPC today and will give us a 10% discount if we have 4-5 jobs. The thread link is here: http://www.skylinesaustralia.com/forums/sh...=&threadid=9426 post there if interested. Link to comment https://www.sau.com.au/forums/topic/9341-hpc/#findComment-142368 Share on other sites More sharing options...
