Does anyone know if this engine will fit into any of these cars?
Depends on what you mean by 'fit'. It's certainly not a bolt in proposition, but with enough time and $$ anything can be done. One of these has been shoe-horned into a 240Z. One problem is that there are no manual gearboxes that bolt straight up, so an adaptor plate would be required. Of course, doesn't matter if you stick with the auto.
Yeah, don't like your chances. John looked into that but if you saw the custom headers that had to be made to squeeze past the chassis rails then the turbo option quickly evapourates. Thats why he went down the supercharging path.
There's a VH45DETT in a S14 thats being built here in QLD, running twin XR6 turbos, custom plenums etc...
Very tight fit, turbos are located behind the headlights, inner guards have been cut to make way for the exhaust manifolds etc...
Be interesting to see how it goes once finish :)
There is a 300zx up here with one in it. He has used the 300zx manual gearbox with it, as thats what was in the car to start with from memory. I guess the major problem you will have is with the width, not so much the lenght.
Is that the orange one?
Yeah the S14 I mentioned is running a VG30dett box aswell.
Twin xr6 turbo's on a 4.5 litre will see decent boost by maybe 5500rpm..
Haha, be an interesting ride for sure once on boost.
Ok, well i was thinking to fir the engine up into a car, leaving the engine standard using Twin T04Z and the other assosciated bolt-on's, and once it grenades just removed and re-build it or buy another engine.
Should be good for over 1000hp me thinks, the car will be used as a drag car but i want to keep it registered and engineered as i would like to be able to drive it on the street every now and then
Cheers
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
