I've just fitted an r33 turbo g/box and heavy duty ceramic clutch in my r32.
I've bled the clutch to the best of my ability and I have a firm pedal.
The pedal is heavy and feels about right for 900kg but it gets progressively heavier all the way to the floor without the over centre easing of the effort I'm used to.
It is difficult to engage any gear from neutral and it crunches on gear changes.
The clutch takes up fast as soon as I lift my foot even 1mm.
It's obvious the pedal is not pushing the slave cylinder far enough for it to fully disengage the clutch and go over centre.
The master cylinder functioned without issue with the previous gearbox and clutch.
The slave cylinder is from ecr33 and has 3/4" bore and was reconditioned prior to fitting.
I've bled all three nipples but could there still be air in the dampener loop? I've heard these can be hard to bleed.
Does anyone know how far the slave cylinder is meant to push?
https://www.sau.com.au/forums/topic/93675-new-clutch-dragging/
Sometimes you have to adjust the takeup point for the clutch when you put a new or new type of clutch in, as it wears the take up point moves further towards the floor.
So jump upside down in the drivers footwell and have a look at the clutch pedal - there is a threaded metal rod that the pedal pushes into the slave cylinder. You need to disconnect the pedal from the rod and turn it to adjust the length
If it is bled correctly and the master cylinder is adjusted correctly then you may need to get a longer push pin for the slave cylinder. remove the old one and get one that is approx 0.5cm longer....even a cut down bolt will do. Then all you have to do is fit the new longer pin in the slave and adjust the master push pin accordingly(no bleeding required to do this either).
Duncan is on the money , i may add you dont need to disconnect the rod to ajust the pedal height .
Is the pedal now as heigh as the brake pedal ?
When you install a new clutch you dont have to bleed the hydrolics , you dont have to touch them at all .
This is a gearbox conversion hence the new clutch and slave cylinder.
I had my mechanic (brother) check it out this morning.
Apparently it was already bled correctly.
I've got 14.5mm travel at the pushrod.
Is that factory spec.?
The pedal height was right but I lifted it 10mm so I can drive the car.
It's not a fix though, more like a bandaid
My brother reckons the problem might be in the new pressure plate assembly.:(
While it's important for the pushrod to be the correct length
a longer pushrod won't usually net more travel because it will only push the piston further back in the slave.
If thats the case you will need either a bigger clutch master cilinder or a smaller slave cil or both .
A smaller slave will make the pedal heavier , a bigger master will make the pedal lighter ( with the same slave ).
If the system has air in it when you pump the pedal several times it will push the slave more , if there is no air it wont make any differance .
Was the clutch new or used ? If the clutch was new and you used the master and slave from the 33 that clutch belong to it should work .
Should work properly but doesn't.
New 900kg pressure plate with cushion ceramic button clutchplate.
I only realised how heavy this clutch is when I drove my honda again. It felt like it had broken a clutch cable.
Slave and master diameters are stock, 3/4"slave 5/8"master, same as r33.
It feels a bit rough through the pedal. It sort of catches a couple of times as you push the pedal to the floor. It makes a twangy clunk noise.
Even though everything else has been double checked and working properly this pressureplate won't go over centre. It's only disengaging half way.
There must be something wrong with the geometry of the combination of component used to assemble it.
It's going back to the clutch place first thing Monday to see what they have to say.
BTW A bigger master cylinder is going to be heavier.
Yes you are right my mistake , smaller master will make it lighter and biggger slave will make it lighter . Big master + small slave makes pedal heavier .
It sounds like you may have a problem with the pressure plate .
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
